bblakely341
New Member
- Joined
- Mar 29, 2019
- Messages
- 2
Changed directions on a buggy I was building so I have quite a few parts up for grabs.
First set of Toyota axles:
Front - IFS housing
- Nitro 30 spline chromo shafts
- Trail gear drive flanges
- 4:10 w/spool
- Trail gear high steer arms w/ARP bolts
- trussed w/ 4 link setup truss and upper link mounts tacked in place
- SOLD 10/6
Rear - IFS housing
- Disc setup with front Toyota calipers
- 4:10 welded diff
- trussed w/ 4 link setup most brackets are just tacked in place
- SOLD 10/6
Second set of Toyota axles:
Front - Standard width housing w/ 3" spacers
- RCV 30 spline chromo shafts (not 300m)
- Chromo hub gears
- 5:29 welded
- 6 shooter high steer arms, welded on 5th/6th stud to stock knuckles
- leaf spring setup
- $1200
Rear - Standard width housing w/ 3" spacers
- Drums
- 5:29 w/spool
- $400
4 - FOA Coilovers
- 2.0 no reservoir
- 16" stroke with 1.5" mounting misalignment spacers
- 2 only used for mock-up / never used
- Fine thread outer tubes / no springs
- dual rate spring setup
- SOLD 10/6
PSC Double Ended Ram
- 2.25X8 PN-SC2209K
- 3 ram clamps
- PSC clevis kit
- Never used
- SOLD 10/6
Eaton orbital valve
- PN 200-0757-002
- 7.32 cu/in per revolution
- weld on mount
- SOLD 10/6
Trail gear 1650 PSI Pump
- New in box
- $350
PSC single ended ram
- 1.5X6 pretty sure PN SC2206
- $100
W56 5spd Trans
- $250
RingR adapter
- Suzuki engine to Toyota w56
- 1.6 tracker bell housing
- $350
Dana 300 / Toyota Doubler - don't want to separate from Toyota case and adapter
- D300 4:1 gears
- 32 spline rear output
- 32 spline front output
- triple sticks, w/ levers and cables
- D300 rear output frame mount
- Clocking ring
- Toyota triple drilled flanges
- 3/4" AL cover plate
- AA Toyota to Dana 300 adapter
- Toyota front case
- $2000
5 - TSLs on Hummer wheels
- 15-39.5X16.5
- Toyota lug pattern
- Double beadlocks with pvc inserts
- rock rings
- SOLD 10/6
1.5X6 ram is mounted on second set Toyota front with 5:29 gears, the double ended ram is mounted to the 4:10 front. The RingR/W56/Dana 300 double is all together in the pic.
If you want to organize and pay shipping for larger parts/tires I can drop parts/axles off with Fastenal.
Everything is located in Chesnee, SC, give me a call or text if you need more info/pictures. 828-two4three - five4zero5.
Front - IFS housing
- 4:10 w/spool
- SOLD 10/6
Rear - IFS housing
- 4:10 welded diff
- SOLD 10/6
- Chromo hub gears
- 5:29 welded
- leaf spring setup
- $1200
- Drums
- 5:29 w/spool
- $400
4 - FOA Coilovers
- 2.0 no reservoir
- SOLD 10/6
- 2.25X8 PN-SC2209K
- 3 ram clamps
- PSC clevis kit
- Never used
- SOLD 10/6
Eaton orbital valve
- PN 200-0757-002
- weld on mount
- SOLD 10/6
- New in box
- $350
- $100
W56 5spd Trans
- $250
RingR adapter
- $350
- D300 4:1 gears
- Clocking ring
- Toyota front case
- $2000
- 15-39.5X16.5
- rock rings
- SOLD 10/6
