ALLJ
- Joined
- Feb 15, 2011
- Messages
- 672
I have a brand new Trail Gear TC style pump 1650 psi on my 22R Toyota motor with their orbital and double end ram on a Dana 60 front the problem I'm having is at idle I have little or no steering until you idle the engine up then the steering comes back the pump whines like its starving for fluid I have the reservoir mounted above the pump and I'm running Royal Purple synthetic in it what they recommend It is running Thur a cooler and its not hot you can touch the reservoir with your bare hand I can remove the cap on the reservoir and its circulating like crazy no bubbles or foaming but as soon as you touch the steering wheel to turn it right or left the fluid stops circulating but will still turn as long as you are not cycling the wheel right to left fast like if you were in rocks or something trying to get the tires to bite if that makes sense its almost like if the pump had a smaller pulley on it to turn faster would help
Any you guys using this pump got any idea or have heard from anyone that has had this same problem
