Triple stick transfercase......
i have been kinda lookin into one of those as well it would be nice to have them in the same place and i would be able to put the switches for my rear window back in the stock location as to just havin them lay on the floor like they are now
I have them in my truck with the 4.3/AT. It was mainly so I could mount the Art Carr shifter on top of the 2nd case where it was easy to reach instead of way up over the trans. Rory was great to buy from and the kit is really good quality.
That is the exact reason I was looking at it since I have the same setup.....anything different u have to do to the dual cases ...that i would need to drop them to install it?
I hacked my tunnel because I was going for a near flat belly but Rory's later design fits better than the early ones inside a console. The only thing you need to do for install is remove the pill in the rear case just like any other twin stick kit. You usually have to lower the cases to do it if it isn't already out.
well i will probably be replacing the tranny soon anyhow so i guess i will just do it all at once
i would go with RAdesigns, daveoffroad is slow right now, family problems. i plan on getting one soon for my dual setup, i like my bench seat
I was looking at those as well, I like this one better because the "levers" are mounted below the axis along the side of the case, should be able to tuck the cases up further to the belly this way...
http://www.davezoffroadperformance.com/store/triple-shifter.html
i have these on a third gen with a 3.0l and a clocked t-case adapter. the only problem i have is i cannot not get my transmission to shift into R because it gets stuck in the t-case shifters. i am thinking if i get a second gen shifter that is shorter it might fix my problem i can take pictures this weekend if anyone is interested
Yes please.
RADesigns.
Installed in my zuk. Haven't actually used it yet but it was the only way to fit an auto shifter. RADesigns makes those too, but I made my own.
