I have searched online and have not been able to find anything. I'm finally getting the chance to start working on my buggy and I need to build some motor mounts. I want to mount the motor transmission and transfer case solid, but I want to be able to remove part of the motor mount so it is easier to get the motor in and out if I had to. My idea was to build the motor mount with two tabs coming off of a plate on the motor and having a piece come off the chassis to the tabs. I was thinking about taking a piece of solid bar stock with a 3/4 hole drilled through it using a bolt through to hold the motor in place. Pretty much like it would be set up with a Poly bushing but using a solid steel bushing instead of poly. Will this work or would it be a problem? If you have done something similar can you post a picture. Thanks.
