UncleCrackers RIg is up and going again!!
UncleCracker
Active Member
Ok, so the last two days, RIX (from the wattora board, also works for titus will) and I ripped apart my 3.slow and replaced the following parts.
Water pump
Timing belt
Cam seals
crank seal
thermostat
Valve Cover gaskets
Throttle body gasket
(I think that is what it is called, maybe air injection unit, the silver part of the fuel injection that sits on top of the 3.0?)
We also replaced all missing bolts, tightened down the ones that were loose.
And than he went through and tuned and timed the thing.
It is running killer now and hopefully no more oil leaks!!! Next comes the pressure washer, condsidering I found 3 inches of dirt and mud hidding under that air injection thingy.
I think that I have decided to keep the biatch, since I am no longer mad at her and she is running properly again. I got a couple new things I want to get done here in the future!!!! :stirpot:
