OK, got everything running again and now I am having an intermittent problem with the motor (when under a load) will lose power, almost like it is shutting down. I think it is happening at about 4,000 RPM's. Normally I can rev to about 5,500 RPM's. At an idle, it will go to 5,500 RPM's no problem. I replaced the fuel filter, cleaned the air filter, cleaned the mass air flow sensor, and am getting ready to change the fuel pump (E8248). I do not think it is the fuel pump since it has 55 psi at start-up and goes to about 60 psi when I rev the engine (in park, not under a load). Someone else mentioned a collapsed fuel line. I am running the 3/8" fuel injection hose with the lining inside of it. This is a little more complicated to check because I have to pull the seats, to pull the tranny cover, to get to where the fuel lines attach to the hard lines coming from the motor. :
Also, I run a check engine light and it is not throwing any codes, so I think my O2 sensors are good.
Anyone have any other ideas. Does a damaged fuel line seem like it could cause this? Could it electrical (please say no uke?
