Walker this Sunday
That is part of main line and that is supposed to be closed still.
they logged that area last November and still have not finished cleaning up there mes. But we can always call Kim and see if we could get a work party together before summers end and try to get that section opened back up.
And the-pics that i posted up was on main line .If you know where the two big stumps are that cause so much body damage to all that don't have rock guards .The logging starts there and goes down to the stump garden.
Duane
I'd be up for a work party to clean up the trail. We stumbled upon that part of the trail which looked like it had been cleaned up. It was not ribboned off and there were no signs saying it was closed like the other section was and the plastic Brown post was up next to the logging road, so we figured it was open.
They logged that area last November? I could have sworn we ran that back in both May and June.
I believe okeedokee's kinda goofed up, as the area shown in these pics are of fresh-logged area by the looks of it....I may be wrong, but it does look like the area between the section they logged off in Nov and the Stump Garden..
And yes, maybe we can all get together with Kim/Alyse, and maybe concentrate a portion of next month's work parties to getting Nov's logged area re-opened (affectionately known as Axle Hill---there was a broken XJ/YJ 35 axle stuffed into a rotten log 1/2 way up the climb thru the roots, hence the name...here's an old pic of said area...I've got other better ones, but can't find 'em right now!!!:redneck:
No The pic look like to me that they are part of main line that did get logged in November and yes they since have been cleaning up some of the mess buts stile closed and well if you are going down to the beginning of main line the first part of main line goes to the right and if you take that you will end up in the logged area . the new logging road goes right across were the trail used to go and if you look on the other side of the logging road you can see the rest of the trial but got block off by the loggers .We should try and get that part opened back up.
Duane
