NTIDWELL
- Joined
- Apr 8, 2011
- Messages
- 629
got a warn 12000 winch with controller and mount plate 2yr old cable on it never broke and no frays works great no problems with it $850obo located in southeast missouri will be traveling thru tn on dec 7 can deliver then here is the specs on it yes i copied off warns web site if you need a pic i can take you one but looks just like any other 12000 warn winch
THANKS FOR YOUR TIME
Nathan Tidwell pm or call (573) 275-8213
Jeep, Truck & SUV Winches: M12000
WARN M12000
A reliable workhorse to meet heavy winching needs
Champion workhorse for heavy-duty winching. 3-stage planetary gear train combined with a 4.6hp series wound motor produce 12,000 lbs. of pulling power. Design is low profile so it fits where you want it.
12,000 lb. (5,440 kg) pulling capacity (single line)
Large frame winch design is designed to handle heavier winch loads
Series-wound, high-speed motor provides fast line speed and strong pulls
Brake provides superior control while winching
Remote-mount control box allows for various mounting options
Durable 3-stage planetary geartrain for smooth, reliable, operation
Remote control with 12' (3.7m) lead
Chip-resistant powder-coated finish
125' of 3/8" (38m of 9.5mm) diameter wire rope
M12000 SPECS/PART NUMBERS
Part number: 17801 (12V)
Part number: 265072 (24V) Contact WARN Customer Service for Availability
Rated line pull: 12000 lbs., (5440 kgs.) single-line
Motor: Series Wound, 12V 4.6 hp, 24V 2.5 hp
Electrical controls: Contactor
Remote Control: Remote switch, 12 in (3.7m) lead
Geartrain: 3-Stage Planetary
Gear ratio: 261:1
Clutch (freespooling): Rotating Ring Gear
Brake: Automatic Direct Drive Cone
Drum diameter/Length: 3.5 in /8.2 in (9cm/21cm)
Weight: 136 lbs. (62kgs.)
Wire rope: 125 ft , 3/8 in diameter (38m, 9.5mm diam.)
Fairlead: Roller
Recommended Battery: 650 CCA minimum for winching
Battery leads: 2 gauge, 72 in (1.83m)
Finish: Argent Gray Powder Coat
Winch Dimensions: 24.37 in L. x 8.45 in D. x 11 in H. (619mm L. x 214.63mm D. x 279mm H.)
Mounting Bolt Pattern: 10.0 in x 4.5 in (254mm x 114.3mm)
12V DC PERFORMANCE SPECS
Line Pull
Lbs.(Kgs.) Line Speed
FT./min(M/min.) Motor
Current Pull by layer
layer/Lbs(Kgs.)
0 30(9.14) 67 amps 1/1200(5443)
2000(910) 14(4.27) 140 amps 2/11120(5044)
4000(1810) 8.62(2.63) 210 amps 3/10340(4690)
6000(2720) 6.92(2.11) 250 amps 4/9770(4432)
8000(3630) 5.80(1.77) 320 amps 5/9250(4196)
10000(4540) 4.39(1.34) 370 amps
12000(5440) 3.86(1.18) 440 amps
24V DC PERFORMANCE SPECS
Line Pull
layer/Lbs(Kgs.)
0 31.94(9.57) 24 amps 1/12000(5443)
2000(910) 11.7(3.57) 105 amps 2/11120(5044)
4000(1810) 9.5(2.90) 129 amps 3/10340(4690)
6000(2720) 8.5(2.59) 152 amps 4/9770(4432)
8000(3630) 7.5(2.29) 175 amps 5/9250(4196)
10000(4540) 6.5(1.98) 198 amps
12000(5440) 6.0(1.83) 221 amps
Above performance specs are based on first layer of drum
Winch Dimensions: 24.37" L. x 8.45" D. x 11" H.
(6.19mm L. x 214.63mm D. x 279mm H.)
Mounting Bolt Pattern: 10.0" x 4.5" (254mm x 114.3mm)
WARN M12000
Gear ratio: 261:1
Fairlead: Roller
Line Pull
layer/Lbs(Kgs.)
Line Pull
layer/Lbs(Kgs.)
