crawlin85cj said:I like the 35 spline offering. It will have its place.
Anyone know the pressure angle / contact area comparison between the 30 spline and 35 spline? Which is actually stronger, just out of curiosity.
mitaker said:I think most of your sales will be with stock 30 spline, and 40 spline spools. If you sell any 35 spline it will probably be for a 14 bolt front as mentioned above
patooyee said:I've always wondered how important splines really are. I know from an engineering point the same dia. with more splines is stronger but they rarely brake at the splined section no matter how many splines there are and look at rockwells and other coarse splined shafts that have few splines with minor dia. less than other axles that break way more easily.
bad80cj said:Andrew Dobosh
krackem said:Why do I know this name does this fella live in Chattanooga, particular East Brainerd area swear i know the name
drich394 said:When is the site going to be up??
From the empty bottle
greenlion said:Got a 16 spline broach (stock rockwell)? No immediate plans, just curious. Would make a 14b/rockwell hybrid easy without having to weld up a stock carrier with rock spiders.
40spline.com said:Spools are almost done. Also, expect to see pricing to come down a little from what we initially forecasted![]()
knaffie said:Any plan to offer all the parts necessary to convert a standard 14 bolt rear axle to 40 spline? New spindles, machined hubs, bearings, seals, axle shafts, locker, etc.
