I have some parts that i will be taking off/not using in the next couple of weeks that i will be looking to sell
Redneck Ram Steering Box for Xj/Tj with PSC 8" Ram and tube clamp with bolt to bolt 1.5" Tubing $450
4- stock tj coil springs in good shape $100
2- Xj/Mj/Tj upper shock adapters $40
2- Zone 12" regular shocks $25
2- Dana 60 30 spline outer shafts $60
Xj/Tj Rubicon Express adjustable trac bar with flex joint and bushing no bracket $100
2- Warn 30 spline lockouts used $150
2- Ballistic Fab Xj/Mj/Tj coil spring/shock mount/ lca brackets in the box $125 these are made to fit d60 axles
2- Xj/Mj/Tj 5.5" Rubicon Express front Coil Springs $100
2- Xj/Mj/Tj 2" Coil Spring Spacers
Xj D30 with 4.88 gear, Detroit Soft Locker, Ballistic Fab Truss, with ballistic fab diff cover and lube locker
Ford 8.8 4.88 gears, aussie locker, spring perches setup for a Xj. Both Axles for $1400
Items are located in Biloxi,MS. As stated these will be coming off in the next few weeks.
