American
Forever Newb
I am building a new buggy and I need $$$. I won't be offended, so feel free to take a shot. I WILL CONSIDER ANY SERIOUS OFFER.
email me at [email protected] and make sure to mention what you are emailing me about. Or text me at 8165207844
Specs:
1973 Bronco chassis, firewall, cab floor
5.0HO out of '91 Mustang: Propane, cam, edelbrock intake manifold MSD ignition, etc (basically a well done mild build with a very healthy lope)
T18
Twinstick D20
d44/9" (big bearing)
1.5" Wheelspacers (1 spare)
Chevy style knuckles and disc brakes
5.38 gears
Spools
Chromos front and rear
CTM U-joints
HD diff cover
"Solid" Drive Flanges
Full Hydraulic Steering
Front 2.0"x16" Fox Airshocks (only a few runs on them)
CAGE Radius Arms (BEEF)
Inboarded Rear Leafs with Anti-wrap bar and Bilstein shocks
39.5 Iroks (3 have 80-90% tread, 1 is almost new)
15" DIY 32 bolt beadlocks (skull pattern)
4-point harnesses
Aftermarket bucket "import" seats
Chopped and Tubed
EDIT: It also now has (done by CBfabwerks):
Front suckdown point
1-ton Tie Rod with heims and new ram mount
1-ton track bar with new mounts
Narrow enough to fit on a U-Haul trailer, but wide/low enough to be VERY stable
This rig will go just about anywhere I point it. I am not afraid to take this down the hardest, and most treacherous trails in the southeast.
$5500 obo $5000 THIS WEEKEND ONLY
Located in Madison, AL.
I plan to keep these, but they can be available at additional cost ALL BELOW ITEMS ARE INCLUDED, THIS WEEKEND ONLY:
*VIAIR Constant Duty Onboard Air System
*Optima Redtop (mounted in rear)
*Smittybilt 8000lb winch (new)
*C6 transmission
Specs:
T18
Twinstick D20
5.38 gears
Spools
CTM U-joints
HD diff cover
4-point harnesses
Chopped and Tubed
*C6 transmission
