mpistolpj
I purchased this YJ to ride while i built my new buggy. I wanted to keep up with my buggy friends and ride the same trails. I works very well. Good power and reliable. My new buggy is getting close and i need the cash to continue on it. You can buy it with the 43's and trail readys or 80% tread toyo mud terrains and black steelies. Buggy located in Mocksville, NC
87 YJ
2000 5.3 Gm truck engine Runs great. Plenty of power, flow master exhaust, Wiring harness and tune by Jim's performance
th 350 trans, shifts great now problems.
Atlas t case
Front axle High pinion ford with detroit locker and 4.56 gears Full new Chromo 35 spline inner and outer with longfield U joints
Rear axle is Sterling 10.25 with detroit locker and 4.56 gears
Full cage tied into the frame in 8 places
New wiring harness from speedway motors(close to streetable) Lacks a few details but could be put on the street with a little work.
Corbeau seats Fat boy models.. a little wider.
Smittybuilt winch with synthetic rope
Front suspension 3 link with panhard
Rear suspension double triangulated 4 link
ORI struts front and rear.. THey are awesome believe the hype..
Full hydro steering with psc ram and pump.
Storage rack in the back
It has an amp and a speaker to hook up your music device for TUNES...
VDO gauges. Fuel level, oil pressure, water temp, and Digital Speedo.(it would take a speed sensor in the atlas for the speedo to work.
This thing will hang with and do lines that some buggies will not. It works awesome and is ready to go riding. It has some dents and scratches but still looks good and is a head turner. I also have a windshield for it with good glass.
PJ 336-909-2076
43's(95% tread) and trail readys $16,500
38's(80% tread) and steelies $14,000.00
87 YJ
Atlas t case
PJ 336-909-2076
