b5010
My 03 dmax won't start.187,00 miles on it.Thought it was a cracked fuel filter housing,change it.INJECTORS
Any help would be great.
InDaShop said:did the filter back off? or the WIF in the bottom of filter sucking air?
If you pump it up will it start and then die?
No leaks. Still doesn't start if you pump it. Just changed the oil in it drained out 5 gallons. Not good.
J.A.B said:Make sure you don't have a tank full of gas - seen it happen more than once
InDaShop said:you drained the oil and it was 5 gallons, you've got a bad injector or some other delivery failure that is filling up the pan.
you got a scan tool? any of these trouble codes P0087, P0093, P1093 will be bad injector juju.
I've not seen one that wont start with bad injectors though. They usually start and run like ****.
