Sold/Expired 1994 Jeep Cherokee on tons
81yota
Active Member
Will sell or trade. I am mainly looking for a V8 ZJ or WJ long armed with a tow package so I can haul my RZR on a trailer. Might consider a 4.0 wrangler, lifted 2000 body style Yukon or Tahoe (non XL), or a rzr 800 as well. Might trade for something else, just let me know...no cars. Need something a little more road worthy. This XJ is done right, it does have some trail rash (mainly on the doors on the passenger side), body is pretty decent, does have some small dents and dings in the body but it has treated me well. Nice weather is here, and its ready to go wheeling. This Jeep does drive decent down the rd. I do have it licensed and insured, but typically stay in town. It does drive 55/65 down the highway alright. Once you hit around 45 it will bounce a bit, but what do you expect for 36" Swampers on bead locks that are not balanced? Has heat but no AC. Compressor is still there, but not hooked up. Had plans to do on-board air. Carpet has been removed as well as the headliner. Used to have a sunroof, but has been patched. Has factory XJ seats and center console. Harness's up front only. If you have any questions, I will do my best to answer them.
Axle's:
1996 Chevy 14 bolt full floating rear axle w/ disk brake conversion 4.88 gears, welded & ring gear has been turned down for shave kit with 80's model 1/2 ton Chevy regular duty brake calipers (disk brake conversion)
1978 Ford F250 3/4 Dana 44 front axle- 4.88 gears w/ Powertrax Lockrite locker & Warn lockouts Ford dual piston calipers & chromoly shafts
Suspension/Steering:
Rusty's Long arm's with Custom cross member/skid plate
YJ Steering box drilled & tapped for hydro assist 1 ton steering with heim's
Hydro assist steering with Surplus Center ram & cooler
Lighting/Audio:
Eyourlife 52" cree IP68 LED Light bar
Hooligan Offroad raingaurd lightbar mount
Sony CD player w/ Aux in
2 Kicker marine speakers up front w/ quick disconnects
Modifications:
All 4 doors have been modified where they will lift off & front door speakers have disconnects. Also have 2 pioneer speakers to throw in the floor for when the doors are off
96+ Front grill/headlights
Armor:
Full cage built on the inside
G-Force 4 point harnesses up front
Rock sliders
Skid plate to cover trans and transfercase
Custom rear bumper with D-loop welded on
Trailer receiver with trailer wiring
Custom front bumper w/ stinger made for Warn 8274
Warn 8274 winch
Unibody has been plated everywhere for strength
Drivetrain:
1994 Cherokee & body w/ 130* thermostat
1993 Cherokee motor (holds great oil pressure, never gets hot, doesn't smoke)
1996 OBDII wiring harness
Optima yellow top battery
NP 231 transfercase with SYE (Slip Yoke Eliminator)
Custom length PEM front & rear driveshafts
No factory gauge cluster, just factory fuel gauge
Has tach, oil pressure, and water temp gauges
Electric fan wired to a toggle switch on the inside
AC compressor is there but not hooked up to anything Plan to run onboard air with it
Wheels & Tires:
8 lug 15" DIY beadlock wheels
36x12.50 Super Swamper's
New Parts:
1/3/2015 Optima Yellow top
2/15/2015 New rear brake line + new rear caliper on passenger side
3/1/2015 Blower Motor
3/29/2015 Front wheel bearings & seals Left & Right
3/30/2015 Spindle bearing & seals Right
3/30/2015 Oil filter adapter eliminated Now takes smaller oil filter Wix or Fram ph3614
4/1/2015 Changed automatic shift handle to the bigger ZJ shifter
4/1/2015 Oil Change Valvoline 10w 30 + Wix oil filter
http://postimg.org/image/q84v4t0wr/
http://postimg.org/image/stzpe56kt/
http://postimg.org/image/tch6km78f/
http://postimg.org/image/va0vg3x11/
http://postimg.org/image/6u8miuyu3/068647f4/
http://postimg.org/image/tsvbiep41/
Located in Eldorado, IL
$7,000 OBO
618-841-5187
Please text before calling if you are wanting to talk on the phone about it vs. sending texts.
