naterade99
- Joined
- Nov 15, 2009
- Messages
- 75
I've gathered parts for a buggy and its time to sell the Toyota. If the truck doesn't sell soon I'm going to strip it down and part it out. The only thing keeping it from the trail right now is a $300 adapter to bolt the atlas back on.
Will sell fixed or as is
The parts...
-1987 ford hp front 60 4.10s welded with spicers and 35 spline outers, solid drive flanges and reinforced knuckles
-Not sure on the year but ford van 60 rear which means larger axle tubes 3.5" with .5 wall thickness and big bore spindles with 35 spline Yukon shafts disk brakes and welded
- both are welded spider gears not to the carrier can be cut and removed
- Complete PSC full hydro with double ended ram and 3/4 heims and clevises not 5/8
- steering cooler with fan
- 2.5" sway away 18" air shocks front and rear
- 6" sway away bumps in the front
- 4 link front and rear
- rubber bumps in the rear
- 1350 drives shafts front and rear
- 3.0 atlas with cable shifters
- mini truck 4.7 crawl box
- stock 2.7 with 5 speed
- rear mounted radiator w/ fan
- prp seats
- marine radio / CD player and iPod dock
- rock lights
- IPF 900 driving lights
- warn 9500 winch
- arb compressor
- 39.5 pitbull rockers on trail worthy fab recentered H1s with PVC incerts
To fix the adapter 12000
As is 11000
pictures to come when it stops raining
The parts...
- prp seats
- rock lights
- warn 9500 winch
- arb compressor
As is 11000
