005 Jeep Unlimited Rubicon, 33,750 miles with 6 speed manual trans
factory air and heat, radio with 6 disc CD player
For sale at $15,500 or trade on a Buggy w/v8, 1 ton axles or possibly on a Buggy project
located in Grand Forks, ND
Has typical bruises/scratches from being wheeled. dent left cowl, one broken door surround, replacement ordered and will be replaced
Left and right sides of windshield frame dented from tree rubs, windshield has no cracks, no rear view mirror, no right hand outside mirror, seats are dirty, rear seat with two minor tears on bottom cushion
It has not been rolled or laid over on the side. Only cosmetic scrapes and bruises to the edges of the tube fenders. I had intended to touch them up when the season was over.
Runs great, drives great on the highway with a little tire shake between 50 and 55 mph. The centramatics do a pretty good job keeping the 37s balanced.
mods:
3.5" RE lift, replaced control arms with Currie complete set of 8 Johnny Joint® Control Arms, Part #: CE- 9100
1-1/4" body lift
(5) 37" MT/Rs. 4 are Classic II - 15 inch Wheels, 10 wide, painted black with rock rash, but no cracks,
spare is on a steely. Three tires with 95 % of tread, two with 40% tread,
33 engineering aluminum belly up kit
Skid Row Offroad Engine & Transmission Skid Plate
4.88 gears in front D44, front tube seals, alloy shafts front, factory air locker
Superior Super 44 Kit in rear axle, 33 spline axles, Detroit locker, 4.88 gears, professionally installed at 33,000 miles
Bilstein 5100 shocks front and rear at 32,000 miles
BTF front and rear diff covers
Tom Woods rear CV drive shaft
Currie heavy duty steering
warn bumpers front and rear
warn tire carrier
Superwinch epi9.0, with in cab winch controls
second set of doors (soft half doors, no provision for uppers)
factory soft top
bikini, windjammer, tonneau cover
centramatic automatic wheel balancers
Poison Spyder crusher corners w/6" flare
GenRight SKUTFF2800, This is the newest generation (G3) tube front fender from GenRight Off Road with a 6" flare for a Jeep TJ or LJ, bedliner coated
Rock Hard Ultimate Sports Cage, with frame mounts, speaker pod rear angle brackets, straight across the rear bar
custom rocker panel protection
no carpet, jeep/mopar vinyl mats instead
fire extinguisher
Cobra CB radio
k&n FIPK
Superchips Jeep Flashpaq Performance Tuner
new brakes @ 25,000 miles all the way around
Fresh lube in transmission, transfer case and differentials at 33,000 miles
mods:
1-1/4" body lift
warn tire carrier
factory soft top
fire extinguisher
Cobra CB radio
k&n FIPK
