customcj7
I'm posting this for my friend. The cage was custom built, and the owner is a no bullshit top-shelf aftermarker support supplier of tires, lift kits, suspension work, and the best custom stereo installer I know for boats, cars, trucks, and ATVs.
Here are the specs:
2013 Maverick Base model
Converted to white plastics
SuperATV Power Steering
Rackzilla
OEM QE front diff
Front left and rear left axles are new
CT rear mud guards
Homemade Sport Low
Custom one-off cage - 7 sticks of 1.75" .120 tubing - Cage is built in 3 pieces - connected with Trail-Gear clamps
Custom rock sliders
Cage has 2" receiver built into rear gusset plate
Viper Elite 4000# Winch with wireless remote
Pro-Armor 5-point harnesses
S3 Powersports front lower arched A-arms
Alex Reed CT Racing rear radius rods
Blingstar doors
Updated clutch bolt recall and new belt cover (due to poor recall installer)
Belt is 3 weeks old
Wheels and Tires
14X8 Hiper double beadlocks with white and yellow beadlocks
27X9X14 Roctanes up front - still in good shape
27X11X14 Roctanes in rear - 2 weeks old
Lighting
Rogue4 40" Single row LED light bar up front
Rogue4 10" Single row LED light bar out back
All wiring for light bars ran through tubing
Stereo (invested $5,500)
Wet Sounds WS-420BT with Bluetooth mounted in metal plate in dash
Wet Sound SD6 6-channel 185W X 6 amplifier mounted behind pre-amp
SSVWorks kick panels with Wet Sounds SW-650 coaxials
SSVWorks sub enclosure with Wet Sounds SS10B under glovebox
Wet Sounds Rev10's with swivel clamps and RGB LED's
Wet Sounds RGB LED controller
Random RGB lighting under dash
Stinger aux dash mount for auxiliary output to other stereo's
Stinger SPP1700 battery mounted under drivers seat for lighting and stereo
Stinger 200A relay to separate stereo battery from OEM battery (so the machine will start if stereo battery goes dead)
Tower speaker wiring ran through cage
Tower speakers swivel 180*, and also remove with one bolt for storage, towing, or cleaning
OTRATTW switches for stereo and lighting
Asking $16,000
Located in Paducah, KY.
Email him or PM me here: [email protected]
Here are the specs:
Rackzilla
OEM QE front diff
CT rear mud guards
Homemade Sport Low
Custom rock sliders
Blingstar doors
Belt is 3 weeks old
Wheels and Tires
Lighting
Asking $16,000
