Sold/Expired 85 Xtra Cab on tons with Trailer
Stretch
Durham, NC
Started life as an 85 Xtra Cab
Front Axle:
Chevy 60 DRW converted to SRW with new brakes (calipers, pads, lines) Rotors are in great shape
4.56 Gear Welded
Yukon 4340 Chromo Stubs
Forged Spicer U Joints
Rebuilt wheel bearings at the same time as axle assembly
RPM Fat Girl Drive Flanges
Solid Diff Cover
Front Suspension:
Bastard Pack of Toyota RUF
Bilstein 14" Travel Shocks
Sky Full Width Spring Hanger and shackles
Rear Axle:
SRW 14 bolt
Disc Brake Conversion with all new parts (Pads, rotors, calipers)
Stainless lines
New 4.56 Gears
Welded Carrier
M&M Offroad Truss
RuffStuff Diff Cover
Rear Suspension:
Custom 4 Link
2" SAW Airshocks Freshly rebuilt with new seal kits and oil
1-1/4" Heims on the Lowers 2" .250Wall DOM
7/8 Heims on the uppers 1.75" .120Wall HREW
All Ruff Stuff and Barnes 4wd Bracketry
Tire/Wheel
42x15x15 TN Cut TSL's 40-50%Tread
Typical Chunking and dry cracks from years of use. They hook like a sombitch. Guy I bought them from said they are roughly 5-6 Years old
15" Steel 3.5" BS Wheels
Drivetrain:
22R on propane using the bigger IMPCO 200/225 Series Mixer. All proper lines and adapters. No hombrew ghetto mess.
Good working G52 Trans and clutch
Stock Dual cases with Trail-Gear Adapter and Marlin Crawler Twin Sticks
Cases really need to be rebuilt and re-sealed and I will include a good working Forward shift case for parts.
BudBuilt Flat Belly Crossmember
Mounts on both Case and crawl box
Trail-Gear Bomb Proof Motor Mounts
New Radiator
Steering:
PSC Resivoir
Trail Gear Full Hydro Pump/bracket Kit
All Eaton crimped lines
PSC Orbital
TSC 2x8 Ram
.250Wall Tie Rod w/ 3/4Heims on the ends
Cage:
All .120wall HREW Interior/Exterior Cage and backhalf
Corbeau Seats mounted to frame/trans tunnel
Front Tube Bumper
Winch:
New Engo 9000S with Synthetic line
Other:
Detachable Steering Wheel
LED Tails and amber marker light
2 Propane Tanks
Trailer is a heavy duty 10,400 capacity equipment trailer with fold down ramps and brakes on both axles. I bought it this way and never got around to titling it. Needs nothing to get inspected and new numbers as a homebuilt. Approx 7 years old. Almost new tires.
Truck: $6600
Trailer: $1600
It is currently in Boone, NC (NW corner of the state). I am moving back to Charlotte, NC in 2 weeks and it will be nearby in Shelby on my friends property.
Open to reasonable offers.
What's bottom $ on just buggy. Im interested if u want send me a text. 256-412-2008
Bump...someone needs a turnkey crawler. Willing to make a package deal on truck and trailer still if buyer is interested.
Up...
Airshocks are rebuilt, has a swaybar on the back now and some new sheetmetal work.
