If its still hase any 'factory' frame, then NOT "buggy", its a Truggy. If its its got an orginal OEM[ish] firewall.
Rec or square tube that came from the steel yard as the base I would still consider a Buggy, provided the rest of the truck is a jungle-gym of course
Basically, if it started as something from the factory, and then was modded to hell = Truggy, if it started from the ground up with a majority of the parts hand-fabbed = Buggy.
*I* would consider a F-Toy a Truggy, or a Buggy watanabe :fawkdancesmiley:
Binder also talked about seating position as well. And thats not a bad way to help with definitions. A low, legs mostly strait seating position is common for a Buggy, retaining a mostly up-right, legs bent position is usually a sign of a Truggy.
As for Craig's List....
Look at how many rolling abortions, or mild-wheeler POS's are listed as "Rock Crawlers" :shaking:
________
Coach purses
