Dana 60 help
kody29
OK I bought a 80s model gm Dana 60 front diff off of a dually what do I need to do to make it standard length?
SRW hubs and associated hardware. I always have replaced the brake calipers and rotors, so I'm not totally sure if the DRW hub parts will interchange. Hope that helps thumb.gif
Single wheel hubs or machine the dually hubs down. I do it all the time. And new wheel studs. You can reuse the rotor if you want but just have to open up the holes to fit the wheel studs
