Trail TJ. 2000 model Sport w/cruise and AC, street legal in Ky and most states. All operational, a blast to drive on the interstate and off road. 5 speed.
Professionally built, no short corners taken. Reliable transportation
wherever you want to go. This is an awesome daily driver and one heck of a trail rig built not to break. Inline six with aprx 100,000 original miles. Runs great, no leaks!
ENGINE
Be Cool aluminum radiator
Flowkooler hi flow water pump
Mean Green starter
DRIVETRAIN
Tera Low 4:1
2 low shift fork kit
1 ton rear CV w/ 8" spline
Hurst shifter
AXLES
Warn 4340 inner/outer shafts
Yukon Super joint kit
Warn premium hub kit
Waggy 44 front w/ 488's and an ARB
9" F-150 9" cut down to TJ width w/ Teraflex Big bearing disc brake kit
35 spline Dutchman Alloy shaft kit
35 spline ARB Air locker
Currie Hi pinion 3rd member w/ 8.8 Reverse rotation 488's
ARB mini compressor
Champion beadlocks w/ full size spare 15 x 8 Baja
37" Good Year MTR's
SUSPENSION
Teraflex ST sway bar kit
1" Tera aluminum body lift
Rubicon Express HD trak bar and bracket
Teraflex modular long arm kit in the front including the long front
uppers and the weld on brackets for the long front uppers
Rubicon mono tube shocks tuned for the coils in the front end
Rear leaf spring conversion using BDS Suspension 2" lift YJ springs SPOA
w/ custom wrap bar
Rubicon Monos tunes for leaf springs for the rear end
ARMOR/MISC
Custom cage
Poison Spyder rear stinger w/ custom grab handles
PS front comp stinger
Rear Poison Spyder Trail corners w/ bracing for the rear stinger re enforced
Spyder tube fenders w/ 3" flare
Goferit Off road 1/4" skid
Herulined tub
Kilby Gas tank skid
Toolbox in back (still have rear seat)
Smittybilt G.E.A.R. Seat covers with tailgate cover
TeraFlex Hand Throttle
Rock Lights
RECOVERY
Warn 9000 LB air winch Power Plant w/ air kit and accessory bag
60" hi lift
Recovery points front and rear
Please feel free to contact (502-368-4049) for more info or pictures. I am asking $14,000. Located in Louisville, Ky.
