Harbor Freight Ram
617_Racing
Stockbridge GA
So... my harbor crap air/hydraulic ram just spilled it's guts all over my floor.
It's for my bender, so just the standard orange ram that everyone else has. I'm guessing the .188 wall DOM was a little too much for it.
Are there any better options? Reasonably priced! I know full electric hydro is possible but not looking to do all that with this bender.
Shoot Id take it back. Or go buy one and take it back. I've heard folks say they bent .250 with it and I know Jduck bends 188 with his all the time.
Yeah I'll probably have my buddy do the ol switch a roo. He is apparently good at it.... There is a store right down the road in Conyers.
It bent the .188 with no issues, it wasn't until I pushed the ram back in on the final bend of the piece that it puked it's guts. I'm more concerned with my bender being able to handle it. It's just a model 3 I picked up at a scrap meet a few years ago for way cheaper than the bender alone cost let alone the die. So I had a 7/8" bolt for the follower to ride on and that bent. I've got a 7/8" tractor pin in it now, seems to of held up for 4 45* bends of .188 so far.
I wouldn't dare try to bend .250 with mine, Jduck has the Rouge bender.
I bent the rod on one from user error, but I'd probably just chalk yours up to being a bad apple. Swap that thing out and try again. Not sure if I'd want to do much .250 wall on mine, you can see some of the pins flexing on .188 wall
Pretty sure the first bolt that bent was only grade 5... I've got a grade 8 on standby if this pin fails. But yeah looking around the other rams are more than twice the price and do the same thing. Plus it's the swag adapter so it has to fit in that 3" hole.
The rogue guy claims that it can bend 2' solid stock I thought?
I'm pretty sure they sheared a pin bending that piece.
Oops! I'm sure mine would of sheared if I hadn't noticed it. I'm not a big fan of how the follower just floats on the pin. Thinking some locking collars and washers to shim it up to essentially make the pin diameter larger, works in my head at least, if I do any more heavy wall bending.
I have had the same one you have for 10 years with no problems. Even bent .250 wall dom with it.
Quick side question guys, what is that bender you guys are talking about ?
I see just a pic with only the feet in, and I'm looking to find a bender able to bend .188 without it being too much of a hassle.
Thanks.
Thanks.
Mine is a JD Model 3 I've got the old style Swag setup for the air/hydro ram and made the vertical stand for it. It bent the .188 pretty easy I would say. But the follower pin seems to be the week link, I bent the bolt I had in it. Maybe if the correct pin from JD2 was used it wouldn't be an issue, but I got mine from a swap meet a few years ago with out that pin. The TSC tractor pin held up just fine though.
I think my ram was just a bad apple.
Mine did that a few months ago on the day of the Super Bowl. Had to shoot up to the store before it closed and get another one. Built 2 cages with it no problem. I plan on bending some .25 wall with mine for me full hydro steering mount. If it doesn't go as planned I have another plan. Lol
