pholmann
I wasn't bitching at all. Just laughing about it.
Mainly referring to 200mph land speed record gofast man. Lolpholmann said:I wasn't bitching at all. Just laughing about it.
zukimaster said:I heard JD is on Farmers only.com also.
TacomaJD said:I used to like you, but you've become quite the douche recently.
As for tire rubbing, I have the exact same unit....mine, WITH SHORTER TIRES and no lift rubbed my front bumper, so I know his will. Not when turning, when going straight and hitting dips, bumps, crossing ditches, etc. Unless all he is planning on doing is driving around his front yard all day.
To eliminate rubbing, he will either have to add a small lift, crank shock preload up, or possibly moving shocks to outter holes to firm up the ride, but I'm not sure if that last option would be enough to prevent rubbing it with 31's. Didn't read that on the internet.....firsthand experience.
pholmann said:On a lot of things I would say that jd may have googled the **** out of it, but on this, he does actually have one so he probably does know what he's talking about. I see this topic as first hand advice. Look at the way he googles and learns **** that he doesn't own. I would say he did ample research before spending money on his sxs lift/wheels/tires/etc. Just a thought guys.
TacomaJD said:Must be magic.
kmcminn said:Josh, when make comments like this. I will make comments that you sound like a know it all.
