jakes89f150
just went through my 2nd set of rear shoes in 2000 miles. First set cracked from heat in the first 100 miles, adjuster was bad. Second set just wore out, brand new adjusters but between the mud and other stuff the audjusters got locked up again.
Its time to convert to disks:
I have no problem fabbing brackets, but this caught my eye.
http://www.currieenterprises.com/CESTORE/productsRE.aspx?id=1229
In that picture it appears that the caliper just mounts to the plate that bolts to the axle tube.
Is that how the explorer caliper's attach?
If so ill just buy an assembly from a wrecking yard and redrill the rotor's out to my 5x5.5 bolt pattern unless someone knows of some rotors that are resonably priced that are 5x5.5 that will work
Any other ideas and advice aswell please
