Axles:
2 Steering Rockwelss with 1 set high steer arms. Both have been welded and mohawked = $1700
Motor:
1997 Vortec 350 (5.7). New heads, new piston, new rings, new timing gears and chain. Bottom end put together, needs top end finished. Has all new gaskets and seals and freeze plugs. Block was done by local machine shop. Also, computer and wiring harness redone by Jims Performance. = $750
Trans:
1 4wd 350 and 1 2wd 350. Both need rebuilt, but have rebuild kit with them. = $200
Tcase:
203/205 doubler with new Jeds doubler and triple stick kit. Is put together for mockup, so needs to be taken apart and gaskets put in. All 32 spline inputs and outputs. = $750
Coilovers:
4 new FOAs with duals sprins for each. C/os are 16" and have 2 - 18" 250 springs, 2 - 18" 300 springs, 2 - 14" 175 springs, and 2 14" 200 springs. = $1100
Art carr reverse patter shifter new in box = $200
TCI Reverse manual valve body = $125
PSC full hydraulic steering kit for rockwells front and rear = $2000
Rockwell pattern H1s with rock rings from trail worthy fab = $750
new in box chevy 350 motor mounts = $50
Everything is located in Crestview FL. These prices are way lower than what I paid for everything so no low balls please.
Mike
Motor:
Trans:
Tcase:
Coilovers:
Mike
