Selling my Truggy. This thing is Bad Ass and works great! Very stable, flexes great, has lots of power and sounds great. It gets compliments and thumb's ups every place it goes.
Here's a list of everything it has and I'm sure I will forget something.
Front half started as 1 ton Chevy frame, Toyota cab with bobbed front, full exo cage, removable full doors and new tube doors. Cab is very solid, not all rusted out but a little banged up but it's not a showpiece! The rear has been back halved, all tube from cab back.
ENGINE: Built 355 (aprox 400-425 HP) run and sound great. Gear drive, Harlan Sharp roller rockers, big cam, Headman headers with Flowmaster mufflers, MSD 6AL ignition with remote adjustable rev limiter mounted in the cab, aluminum radiator. Runs on propane
TRANS: Rebuilt turbo 350 W/shift kit, 2800 stall, B&M shifter, twin stick 300 case
s347.photobucket.com/user/robyndodd12/media/IMG_1424_zps8l6jy7qf.jpg.html]
REAR: Full float corp. 14 bolt, welded, 538 Yukon gears, Disc brakes, chromoly shafts, 4 linked (DOM ¼ uppers, 3/8 lower links), 18" Fox 2.0 shocks
FRONT: King pin Dana 60 (just had bearings, races, and seals replaced), Detroit locker, 538 Yukon gears, Bobby Long U joints, 35 spline outers & drive flanges, disc brakes, leaf springs w/ shackle reversal, rancho RS5000 shocks, PSC single ram hydro steering.
LIGHTING: 40" light bar, Hella headlights, LED tail lights (both work off original switch), 7 rock lights, blue light strips in cab.
MISC: 12000 lb Badlands winch (front) and a rear suck down winch (both controllers are mounted in cab), Auto Meter monster tach with shift light, CB, 4 pt harnesses (have straps to make 5 pt), front and rear line locks, Optima yellow top batt. And will come with 4 propane tanks (2 fiberglass & 2 aluminum).
TIRES: Set #1 are almost new 42/15/15 TSL SXII's on Allied 32 bolt beadlocks with aluminum rings (only 5 runs on them) some rash, no plugs or patches.
" OR"
Set #2 are 38.5/11/16.5 TSL cut Boggers 6 total , 4 are on 32 bolt DIY beadlocks W/ no plugs or patches, the fronts are 85% and the rears are 50-60%, 1 spare same as fronts on steel rim (has 1 plug) and 1 tire uncut 100% tread.
Truck will be sold with one set or the other "NOT BOTH" unless $$$ I right or added!
Selling due to health. No low ballers because I'm not giving it away!! Truck is turn key and ready to hit the trails.
May trade for nice toy hauler, side by side, diesel truck, muscle car, rat rod, hot rod, street rod, classic truck. NO boats, dirt bikes, 4 wheelers, tractors, lawn mowers.
I DO NOT NEED JUNK or HELP SELLING. Thanks for looking!!
Please Call or Txt Bruce at (217) 722-2534 NO Emails and if it is still listed it is still available so please don't ask!
Tag: Diesel, truck, muscle car, camaro, chevelle, nova, C10, rat rod, street rod, hot rod, Classic truck, race
Located in central Illinois
