Rockwell help - rear steer project
TG22.
Lenoir city
Any one know the correct procedure for adjusting the nuts on the Rockwell third member?(The large bearing adjusting nuts on the bull gear)
Ive got the axle stripped and shaved, and the locker ready to be installed. I want to drop this back in the third, but I cant find the specs or measurements for doing so
Thanks!
Get some gear marking compound and center the bull gear to the lower pinion. Tighten the spanner nuts tight but not to tight then lock them down.
Ive drilled the third for the 180 turn for centering. However, after a long night of fab I realized I have the bare axle mocked up under my jeep with the chunk on the driver side. I plan on having tie rod in the back- but I leave the axle this way Ill have to swap knuckles from their stock location if I'm thinking correctly
What will this affect??
