mikemounlio
- Joined
- Oct 20, 2014
- Messages
- 176
I finally have a buggy. I have been spending the last couple weeks doing all the small stuff that needs done to it. Winter is coming and i will want to tackle a bigger project. I am thinking blow though turbo would be easy as i am on propane already.
The buggy has a mustang 5.0 that was FI but the propane kit was added. It has an MSD Ignition system. 425 mixer, not sure what carb is used. not sure about the other items. The buggy runs great and has power. I am simply looking to take it to the next level step by step.
The main reason for wanting a turbo setup is simply to have one, have a bit more power, and have some sweet sounds. I dont want to add a ton of power. I would be happy with 300hp. The stock 5.0 has about 205+ hp. the stock block is good for 450+ but i dont want to build it that high just yet. From what i have read the stock 5.0 is good with 6-8psi. I would be more then happy at 8psi. I will try to get some pictures up tonight. From what i have read so far adding a turbo to this setup would be rather easy.
Any info or opinions would be great.
