Sold/Expired (Sold) 1994 Toyota Pickup 5.3 Atlas Tons 40s
Status
Not open for further replies.
Ewoods
Wheelin and Dealin
N.E. Alabama
Started out as a 1994 2wd Pickup
Finished in November 2015
Motor:
2004 5.3, came out of a wrecked GMC 1500 with 180,xxx miles
Jim's Performance stand alone harness with his 25HP tune
Custom poly motor mounts
Summit block hugger headers
Summit universal radiator, trans cooler with electric fan
All stainless braided fuel/transmission lines with AN fittings
E2000 fuel pump
Corvette fuel pressure regulator/filter
Fresh water pump and thermostat
Transmission:
TH400, came out of a 1984 Chevy K30 CUCV
Converted to long tail shaft
TransGo shift kit
Monster Transmission converter
ArtCarr gated shifter
Lokar braided dipstick
Transfer Case:
Atlas II 3.8
1350 flanges front and rear
Cable shifters
Driveshafts:
Built by The Offroad Connection
1350 u-joints
Dual cardan front and rear
Long slip front
Tom Woods high angle joint in front
Axles:
Both came from 1984 Chevy K30 CUCV
Dana 60 front
Blue Torch Fab diff cover
4.56
Spartan locker
Yukon 35 spline chromoly outters
Yukon Hardcore locking hubs
3/4 ton brake conversion
1350 yoke
14 Bolt rear
4.56
Detroit locker
Disc break conversion
1350 yoke
Tires and Wheels:
40x13.5R17 Maxxis Trepadors (Bias)
17x9 Allied steel beadlocks
Spare: 40x13.5R17 Pro Comp Xtreme Terrain on black steel wheel (brand new)
Suspension:
Front-
Toyota rears up front with a mix of YJ leafs
Sky's Offroad full width hanger kit
Plated frame rails
WFO degree shims
Ruff Stuff U bolt kit
Bumpstops and limit straps
Bilstein 5100 shocks
Rear-
63 inch Chevys
Ruff Stuff hanger kit
Steering:
Stock pump converted to remote reservoir
PSC reservoir
PSC single ended ram
PSC steering cooler kit
PSC orbital
Ruff Stuff tie rod kit with heims
Interior:
Fresh Raptor lined floor boards
Grant steering wheel
Auto Meter oil, fuel, and transmission temp gauges
Insight CTS gauge for tach, water temp, and volts
Heat works excellent
Misc:
All tube work is 1.75 D.O.M.
Optima Red Top with Blue Torch Fab mount
Trail Worthy Fab 40in light bar
R.C.I. 19 gallon fuel cell
Sky's Offroad Chevy 1 ton brake master cylinder conversion
Clear Alabama title
Runs and drives great. Has been very reliable since I built it. Driven it to work multiple times (45 miles one way). Only selling to start another project. No trades.
Also will come with another 94 2wd Pickup parts truck. Just cab, doors, fenders, hood, and frame.
Asking $14,500
Ashville, AL
Evan - 205-451-8769
Re: 1994 Toyota Pickup 5.3 Atlas Tons 40s
If only i wasn't 16,350 dollars short I'd be taking this home with me :dblthumb: Good luck with sale man! drool
Beautiful truck.
What size radiator and fan do you have?
Dang it man that is awesome! Shouldn't have any trouble with selling it :dblthumb:
Location? Are the treps stickies?
the_white_shadow said:
Beautiful truck.
22in wide by 19in tall. 2 row with trans cooler. I had a local radiator shop weld some tabs on for me. 16in fan.
Ashville, AL. And no they are not since I drive it on the street a pretty good amount.
This thing is incredibly clean, and well put together. Badass street or offroad toy!
$10,000 plus half a case of Natty light? Might even upgrade you to Keystone's if you talk just right to me. loller.gif
If you can swing a case of High Life, you got a deal :fish:
Status
