ALLJ
- Joined
- Feb 15, 2011
- Messages
- 672
Toyota buggy built off a 4 Runner frame 22r runs on propane 5 speed dual stock cases Chevy 60 front 14 bolt rear 43 SXs NON STICKY Bead locks buggy is about two years old located in South Pittsburg TN 37380 message me for more info price is $23,500 CASH OBO will consider trade on a 4 seat SXS no warranty sold as is
The build thread is on Hardline under tech it is number 9 smurfy90 on here did the tube work
Buggy has a VIN # and can be registered tagged and insured !!!
FRAME
85 model 4 Runner
Tubing 1:3/4 DOM
1/2 flat belly plate
Sky's one ton front spring bracket
AXLES
Chevy 60 front
High angle 60 to Toyota flange
4:56 s Yukon Grizzly Locker
35 spline outers spicer 806 u joints
Drive flanges
3/4 ton rotors and calipers
Blue Torch caliper brackets
BTF diff guard
Sky's high steer arms
14 bolt rear
High angle 14 bolt to Toyota flange
4:56s Detroit Locker
Stock axles
BTF diff and pinion guard
Sky's Toyota to GM master cylinder bracket
Front and rear have stainless braided brake lines
STEERING
Trail Gear 8 inch double end ram
Trail Gear orbital valve
PSC pump
Synergy Suspension adjustable steering column
Quick release wheel hub
SUSPENSION
63 inch Chevy springs in rear
Toyota rears in front with added leafs
Sky's u bolt plates front and rear
Bilstein 5125 14 inch shocks in front
Bilstein 5125 10 inch shocks in rear
ENGINE TRANSMISSION
22r stock rebuilt when buggy was built
Propane with dual tanks all parts were new
Headman header with Flowmaster muffler
Spectre air intake
5 speed transmission new clutch when built
Marlin Crawler dual case adapter 10 degree rotation
Stock gears in both cases
Rear case has Marlin 30 spline HD chromo rear output shaft
Toyota u joints on front and rear shafts
Motor trans and cases are solid mounted
INTERIOR
PRP Daily driver seats with water mesh
Driver seat has adjustable slider
PRP 5.3 Competition 5 point seat belts with black pads (crotch belts not installed)
Fire extinguisher
Cup holders built in console
All floor pans and console are removable
Side panels are removable
Floors have bed liner on them with drain holes
TIRES AND WHEELS
43 X 17 SXs NON STICKY !! All hold air no plugs or patches
32 bolt single bead locks
EXTERIOR
Kubota orange
Red Neck Lights LEDs on front
Super Brite LED rock lights
Rugged Ridge 8000 LB winch with rope and inside control on console
Clevis mounts front and rear
Mount for Yeti 35 cooler in rear
Red top Optima battery
Buggy has a lot of room inside and is easy to get in and out of and is very dependable you don't have to work on it every time you go out message me with any questions
FRAME
85 model 4 Runner
Tubing 1:3/4 DOM
AXLES
Chevy 60 front
Drive flanges
BTF diff guard
14 bolt rear
Stock axles
STEERING
PSC pump
SUSPENSION
ENGINE TRANSMISSION
Spectre air intake
INTERIOR
Fire extinguisher
TIRES AND WHEELS
EXTERIOR
Kubota orange
