Black11330
New Member
- Joined
- Jun 19, 2020
- Messages
- 3
Chassis
TJ Frame w/dovetailed body
Tubed front and rear sections
1.75" .120 wall Cage tied to frame
1/4" armored steal plate belly pan (25"ground clearance)
1/4" armored steal rock sliders (30" ground clearance)
Warn Zeon 10 winch w/TRE synthetic rope& Factor 55 Flat Link
Full PSC Hydro Steering (approx. 2.5-3 turns lock to lock)
Older Corbeau reclining seats & harness's
approx.113" wheel base
PowerTrain
1997 5.7L Vortec TBI fresh rebuild to mostly stock w/ headers & FlowMaster 12, 2 into 1
TH 400 Trans.(rebuilt same time as engine) w/ Winters Shifter
NP241 Transfer Case w/SYE
Shaved/spooled 14 bolt Rear 4 Linked w/ rough Country TJ Coil Springs 5.13 gears
Custom Shaved/Detroit Locker 14 bolt Front,4 Linked w/ King 16" Coil Overs 5.13 gears & Yukon Shafts
Both Front and rear ground height is 13"
Front & Rear 4 links are 2" with 1/4" wall DOM & Barnes Heim Joints
5-Steal Welded Bead Locks w/ 42.5"x13.50"x17" TSL Boggers
accessories
Master HD Kill switch
Optima Red Top Battery
Matrix H.I.D. off-road headlamps
42.5" over head light bar
Rock lights at all 4 corners
Gauges/Tach./Horn
RCI 12 Gal fuel cell w/ braided S.S. fuel lines
Custom Dash w/Bluetooth Stereo and Marine Grade speakers
Aluminum Grab handles
Removeable Hard doors
This Extraordinary Build has only been wheeled a hand full of times. I am the second owner from the original builder.
If requested I can send the build pix.
The boggers still have nipples on them.
any Serious buyers can inquire. DM me at my cell 513-313-1112.
I am not on Hardline everyday but will do my best to respond. best to DM me.
PowerTrain
accessories
Gauges/Tach./Horn
