Sold/Expired tj tube frame atlas fuel injection ( sold )
jeeptrader
Iam going to sale my tj don't have time to ride it is new it has three rides on it I may take part trade for rzr 800s or 900xp . Motor sb chevy 383 stroker four bolt maine eagle rods and crank speed pro piston Pro comp aluminum heads Roller cam lifter and rocker are all roller pro comp. Fast fuel injection system headman headers power master xs tork starter power master 200 amp alternator . Transmission 400 th full manual vb aluminun deep pan build by ptc. Torque converter ptc 10" nitrous. B.W transmission cooler with fan. Front axles is a dana 60 513 gears locker yukon 35 splin 4340 axles yukon drive flange. rear axles 14 bolt 513 gears and locker. four link front and rear 250 wall dom 1 1/4 heims on bottom top has 250 wall dom with 7/8 heims fox 14" coil over front and rear fox bump stop on front. Atlas 3.8 with 32 spline front and rear, rear yoke is a four bolt flange 1410 spicer join. Drive shaft are high angle long travel 1410 spicer joint. psc full hyl sterring pump, orbital, ram double ended and cooler are psc. corbeau ss baja seats, yellow top batter, quick release steering wheel, Wilwood dual master cylinders disk brakes all four wheels, warn winch 9500, Transmission has J.W bellhosing on it , 10 gallon fuel cell for more info called 256-566 1066 $24500 Jeep frame has been front and back half has been tube may take part trade for rzr 800s or 900xp jeep is in moulton al tires are 44 tsl on 32 bolt bead lock also have spare wheel and tire
Re: tj tube frame atlas fuel injection
here is a few more pic
any interest in a custom fatboy and some cash?
