BigBluePile
Those cases are super easy to tear apart
The bearings on the part of the case that meets the transmission.I would think they need grease?No?Thay had grease on them.Sooo.......? LOLGrease? Fill it w/ oil and be done. If you're really worried, jizz some oil on the bearings during install and then be done.
Yes 4.7 gear set .Those bearings will get lubed just fine with gear oil. If you want to put some bearing grease on them, go ahead.
So, this case has a 4.7 gearset in it?
