J
Joc
Guest
1987 Samuria with ***le
1.6L tracker motor w/ got propane kit. Motor does not smoke, leak or burn oil.
comes with 2 propane tanks
5 speed manual tranny
6.5:1 transfercase with ZOR craddle
new gm altenator
new psc pump
hand throtle control on shifter
blue top optima
Front axle:
toyota front axle
5.29 gears,spool
longfeild 30 spline axles
arp steering studs
arp drive flange studs
longfield drive flanges
trail gear high steer arms
full hdy. steering,psc pump and resevoir
3 link
14" Fox coilovers w/res
professionally built 1310 driveshaft
Rear axle:
custom built toyota rear steer axle
longfield 30 spline shafts
full spool
5.29 gears
6 shooter knuckles
arp steering studs
electric over hydraulic steering pump
aluminum drag link with steel outer sleeve
1 linked with 14" Fox coilovers w/res
Wheels/tires:
37" BFG red lables on trail gear beadlocks. front tires are full of water
105" wheelbase
Warn VR8000 front winch synthetic rope, doubles as a suck down winch
Warn RT25 rear suckdown winch
Corbeau seats with Crow 3" harness
Cd player w/mp3 input
CB radio(needs new antenna)
Spare parts:
has a new micky thomson 37" spare on black steel wheel
spare driveshafts front and rear
has hard doors with glass
spare transmission
This rig will go with the big boys no problem!
SOLD
located in tuscumbia, al 35674
new gm altenator
new psc pump
blue top optima
Front axle:
toyota front axle
5.29 gears,spool
arp steering studs
3 link
Rear axle:
full spool
5.29 gears
6 shooter knuckles
arp steering studs
Wheels/tires:
105" wheelbase
Spare parts:
spare transmission
SOLD
just messing with u josh
