Sold/Expired NEW DANA 80 47 Spline Spool NOW AVAILABLE!!!!
RocksolidPerformance
Active Member
Grand Rapids Michigan
Rocksolid Performance is answering the demand for a Dana 80 47 Spline spool. The Spool is cut from a solid piece of billet. The spool requires use of oversized bearings. Does NOT require any modification to housing. These Spools will soon be available for pre-sale.
Re: Re: NEW DANA 80 47 Spline Spool
Awesome!!!
Good work!
Sended frum da cumputar box in my hands eh.
DANA 80 47 Spline Spool !!!! LOWER PRICE
NEW Lower price. We have made some upgrades to our machining center and can now reflect our cost saving on machining these spools to you our customer. The Ouverson spline is different from the RCV Spline, due to this this one of them is less than the other due to the way the splines are put into spool. The RCV Splined Spool is $900 for spool with oversized bearings and shim kits. The Ouverson Splined spool is $1100 With oversized bearings and shim kit. Get $50 off each spool When you buy two at once.
