Rebel Customs
Member
- Joined
- Mar 3, 2013
- Messages
- 10
Its 2wd for now. strpot
Its a 1949 Ford F-2 3/4 ton. The running gear is going back to the P.O.
Yall know whats next. hacck
Details:
SBC 383, fully balanced, 10.7:1 compression ratio, edelbrock aluminum heads, .501 lift cam, eagle rods/crank, edelbrock air gap intake ect...
Axles: 14bff/King pin D60 both have detroit no spin lockers and 4:56s
Trans: In process of building, reverse manual valve body, stall converter, new clutches, ect
Suspention: 56" chevy springs out back, 52" springs up front
Steering: Full hydro, TSC ram, PSC pump and orbital
Cage: Not built yet, will be front to rear, similar to circle track cars.
Frame: Stock C channel Ford frame 3/16 wall. Getting boxed front to rear ontop of full cage.
This is not a mud truck. Majority of use will be on the rocks.
Details:
