rdw0007
engine
5.3
ls1 cam
heads milled .30
new intake
new injectors
coil packs
plugs and wires
new jims performance harness and tune
rci fuel cell
in line pump
seats
prp seats
g force pro series harnesses
cooling
rear mount radiator
2 12in fans one pushing one pulling
4 flume alum radiator
trans
new one ride th350
red racing clutches
reverse manual valve body
transfercases
doubler
fresh np 203
np 205 31 spline input
front axle
gm king pin dana 60
new yukon 4340 inner and outer 35 spline zero rides on them
4.10 gears
locked
3/4 plate high steer
single ended ram
four linked
18in fox 2.0 shocks now has new foa 16 in coil overs with reservoirs
rear axle
14 bolt
disc brakes
4.10 locked
four linked
18 in fox 2.0 shocks
wilwood dual brake set up
tires wheels
44x 19.50x16 cut boggers 90 % tread
mrt bead locks 16x10 with 3/8 rebar bent and welded to inside wheels for hard hit protection
I'm sure i am forgetting something will try to get more pictures up message for details located in montevallo al asking 20k obo
call or text Ross 256-596-0103
built 5.3 ls1 cam heads milled .30 new injectors jim's performance harness and tune new th350 with red racing clutches reverse manual valve body doubler np 203 np205 new joints gm dana 60 king pin front 35 spline outer drive flanges full hydro steer 3/4 plate high steer arms 4.10 gears locked rear 14 bolt 4.10 locked front and rear 4 link fox 18 in shocks all way around 5 point harness 44 grooved boggers 90 % tread mrt bead locks
5.3
ls1 cam
heads milled .30
new intake
new injectors
coil packs
plugs and wires
rci fuel cell
in line pump
seats
prp seats
cooling
rear mount radiator
trans
new one ride th350
red racing clutches
transfercases
doubler
fresh np 203
front axle
gm king pin dana 60
4.10 gears
locked
single ended ram
four linked
rear axle
14 bolt
disc brakes
4.10 locked
four linked
tires wheels
haha bump for ya buddy!
