Sold/Expired 203/205 doubler ///// SOLD ////
scoggins511
maken them skinny
Hickman
203/205 doubler passenger side drop that fit a th350 it is clocked up flat so clear a skid plate also have offroad designs shifters. I Had this built couple years ago by a guy in McMinnville Tennessee only Crawled with it in a truggy ab 5 time then I started building a buggy and it's been in my shop floor since. now I also have another 203 that will fit to a th400 I'll throw in if ya need it. $900 located in Lyles TN 6154831456 thanks
Re: 203/205 doubler
Whats the overall length? Are the yokes 1310/30/50? Are the triple stick ORD shifters included?
Bear with me, Ive done some research but im not completely sure. I have a 700R4. Based on the ORD website I would just need to get the spacer to bolt it to my tranny right?
GM TH700 R4 / 4L60E Automatic Transmission:
The TH700 has the same bolt pattern on the back of the transmission as the TH350 and uses a 27 spline output shaft. Since the TH700 only came with the NP208 or later alum t-cases, it's shaft stickout is a little over 2" in factory form. One difference to be aware of is that the TH700 uses 4 metric bolts to secure the adapter to the transmission case.
There are three ways to bolt to the NP203. They are very similar to the TH350 mounting mentioned above.
1: replace the output shaft in the TH700 with an aftermarket output that sticks out of the case by about 7/8" (click here). This makes the output identical to the TH350 and you use a TH350 version NP203 with the 27 spline input and a TH350 to NP203 factory 1" thick adapter plate. This is the shortest method and is the preferred way if you are working in a transmission rebuild at the same time.
2: Use a spacer (click here) with a factory TH350 to NP203 adapter. This method is longer and has one more spot to leak but if you aren't tearing apart the transmission and don't need the absolute shortest setup this is a good way to go.
3: use the factory TH700 output shaft and the factory TH700 to NP208 adapter housing with a TH350 version NP203. You will have to re-drill and tap holes in the NP203 gearbox to be able to bolt it to the original NP208 adapter housing. You may also have to do minor machine work on the input bearing retainer on the NP203.
Re: 203/205 doubler
The other 203 that is for th400 will it just swap out with the 203 that is on there now if so is 1000 your bottom dollar?
Re: 203/205 doubler
Yes it should swap out. And yes 1000 firm.
