JK Buggy(s)
rock mafia
#27. Building this for someone in AL. LS3, TH400, Atlas, 14 bolts. Chassis is 54" wide around 114" WB.
Re: JK Buggy
They just keep getting better :dblthumb:
Curious why the rod ends at the axle on the uppers are mounted with bolt horizontal on front and vertical on rear. Packaging / space issue?
Re: JK Buggy
Thanks. A number of others have done it that way. It's stronger holding the axle side to side with the joint loaded that way, but will wear faster. It fit better, so I thought I'd try it.
Re: JK Buggy
Looks good, got a feeling I know who this belongs to!!
Re: JK Buggy
whiskeymakin said:
Hopefully there is another Plate to double shear the steering heims?
Looks nice! Low c.o.g.
That's just for mock up. Probably use some different arms.
Thanks.
