Posting for Tim Cantrell
Chassis was reworked in 2010
AXLES
SXOR Dana 60 housings
Dynatrack knuckles
Spidertrax front axles with CTM joints
Yukon rear chromoly shafts
OX air locker in rear
Spooled front
3.73 gears
8 lug
Brakes
Willwood 4 piston calipers
Spidertrax hats and light weight rotors
Braided .004 rubber coated brake lines
Steering
PSC steering pump and resivor
PSC dual ended ram
Engine
383 Stroker
Dynoed at 602 hp on 102 octane and 597 ft lbs torque at 5800 rpms
engine currently running on Propane set up with twin Propane systems
MSD gel filled ignition
MSD coil
MSD distributer
Alum dart heads,polished and ported
Direct drive camshaft assembly
Custom ground cam
Custom built Jet coated exhaust
Transmission
two speed custom Powerglide,guaranteed to withstand 1200 hp
Transfer Case
Stack
Twin stick
Cooling system
Griffin alum radiator with cooling fan
Transmission cooler with fan
PSC steering cooler with fan
Oil cooler with fan
Wheels and Tires
Trail Rated Alum beadlocks with like new Trepadors
Suspenion
16" ORI Struts
4 link
1.5" 771 alum rear links
1" cold steel upper links
7/8" heims
Misc.
Corbeu suspension seats
propane bottles and brackets
Lexan floors
Fiberglass VW bug hood
Window nets
Lights and guages
Cheetah shifter
New paint/powder coat and wrap
Spare parts
MSD ignition box and components
Plug wires
Ring and Pinion
Front and rear axles with u-joints
driveshafts,2 fronts-2 rears with u-joints
PSC dual ended ram
PSC pump
2 orbital valves
misc. hoses and fittings
remote transfer case shifters with acc.
B&M pistol grip shifter
Warn RC 9.0 winch with nylon rope
Link arms 771 alum with heims,8 total
6-2.5 16" Fox Nitrogen shocks
6-2" Fox bump stops
4-race radios with head sets
2- Spidertrax lightweight rotors
Heim joints and bushings
Small misc.parts -too much to list
All is located in Kennasaw Ga.
Contact Tim Cantrell
770-560-4781
I dont have any current pics,maybe Nolan has some he can post.Chris Tobin has some of the latest pics from XORRA Jellico.
Tim says the car is ready to race and he just needs a break.
Asking $44,000.00
He will sell the car less engine and trans,call for price if your interested
AXLES
Dynatrack knuckles
Spooled front
3.73 gears
8 lug
Brakes
Steering
PSC dual ended ram
Engine
383 Stroker
MSD coil
MSD distributer
Custom ground cam
Transmission
Transfer Case
Stack
Twin stick
Cooling system
Oil cooler with fan
Wheels and Tires
Suspenion
16" ORI Struts
4 link
7/8" heims
Misc.
Lexan floors
Window nets
Lights and guages
Cheetah shifter
Spare parts
Plug wires
Ring and Pinion
PSC dual ended ram
PSC pump
2 orbital valves
6-2" Fox bump stops
770-560-4781
Asking $44,000.00
