Emery built n Jerry rigged
Stephen is almost finished with the small detail. Then to my shop for weld out and final assembly. The aluminum tubes will be attached to the frame rails for coolant Radiator to engine
I'll be finished with a job I'm on next week then get home and get it to my shop Suppose to have a month or two off so should get a lot finished
man this is such a cool rig overall. Some really good details and ideas used throughout. I would shamelessly copy things off of it in a heartbeat.
We have it sitting on the bumps right now cause I haven't scaled it to figure spring rates. I think it's 20" to the belly
Did you clear coat it or use the patina wax or whatever it is? I saw the wax get used on Hardcore Fab's Hooker and Blow.
I used boil linseed oil. Takes it a couple days to dry. I've used penatrol on other patina works good to
10-4, have to admit I would not have thought to go that direction. I know to use linseed oil on tool handles etc never would have connected the dots to use it in your application.
Used it on several rat rods. Worked good
Custom overflow and patina match bed panels
How's about some updates for us @hink311 ?
Due to gas prices had to go back to work. Of all things building wind turbines. I did get back brakes finished Got to get my back axles ordered then scale it and order springs Then to tuner Hopefully soon. Its been awhile I'm ready to wheel
Well that's interesting on rising gas prices causing you to go back to building turbines but pretty cool.
Thanks for the mini update.
