Sold/Expired 05-11 F250 Machined Highsteer Knuckle and Arm
RocksolidPerformance
Active Member
Grand Rapids Michigan
05-11 Machined knuckle for high steer. Arm is made of 1" mild steel and CNC machined at our shop. The knuckle is double keyed for added strength. We have been running this setup for over ten years. The first ones were only single keyed and we had no issues. We saw room for the improvement and designed new arms and redesigned the knuckle machining to add the second key. You will not be able to run your vacuum hubs without modification. This setup lets the arm swing inward allowing the use of 4.5" backspacing rims. These are for off road use only.
Check out pricing at our online store - http://www.rocksolidperformance.com/05-11-f250-machined-highsteer-knuckle-and-arm/
