Sold/Expired 09 EOR 321 Buggy
Jwhit55
Enigine/Trans:
351w on propane (will include 5 bottles)
Aluminum Ford Racing Valve Covers
KRC Aluminum PS Pump and Bracket
BBK Equal Length Ceramic Shorty Headers w/ header wrap on exhaust tubes
Edelbrock Performer Intake
Chevy One Wire Alternator
HEI Distributor
New Milodon High Flow Water Pump
New Miloden 160* thermostat
Ford Motorsports performance Aluminum pullyeys
Motor is very clean and very strong
Built C6 transmission w/ cooler mounted on the firewall.
Ford Racing Plug wires w/Plug Boots
Engine has been completely gone through
all new gaskets and seals
Transfer Case:
Atlas 4.3 w/1350 yokes
Axles:
Front - Ford HP60 in the front with 4.88 gears, Chromo 35 spline inner/outers, Nitro 300m U-joints without the grease fittings, RPM offroad HD drive flanges, all new bearings and seals, races, Blue torch fab front trus, PSC double ended ram, detroit locker, original caliper brackets w/new calipers adn shoes, reid racing knuckles w/ ballistic high steer arms, upper and lower kingpin rebuild kits
Rear- GM 14 bolt w/ 4.88 gears, spool, new bearings, seals, races, disc brakes, Blue torch fab truss with pinion guard
Interior - Custom aluminum dash, All autometer carbon fiber guages (oil pressure, oil temp, trans temp, volt, water temp, and tach w/ shift light)Kirkey 16 wide seats w/crow harnesses , PSC Orbital, Art Carr sidewinder shifter
Misc. - Bilstein 16 coilovers, 2 inch aluminum links, all 1.25 QA1 heims, Grote LED lights mounted on the stinger, all stainless brake lines, rear mounted aluminum radiator w/new dual DERALE high output electric fans w/shroud, aluminum PSC cooler, PSC PS reservoir, Warn 9.0 RC comp winch
This buggy has made it through some of the toughest trails at Windrock ORP and Harlan.. The buggy is very tough and can take a beating all day long.. I am sure that I am forgetting something send me a message or e-mail me @ [email protected] ... Please NO LOW BALL offers and NO TRADES!! I am located right outside of knoxville tn
$28500
Thanks, hate to do it but somethings have come up and its gotta go!!
Appreciate all the interest but things have seemed to work out so ive decided to keep it!!
