DRM
Front 60 started life under a 79 Dodge, was narrowed to just under 65", External 30spline flanges & stubs (I also have a set of locking hubs around here somewhere I will include), 4.88 gears, ARB locker, HD diff cover, Artec full truss with 4 link mounts and mount for double-ended ram, high steer arms, converted to 3/4ton GM disc brakes. Will include ARB compressor and new braided and coated ARB line as well.
Rear is a '71 GM Dana 60 rear, Approx. 65" wide, 30 spline, welded, HD diff cover, 4.88's, converted to 3/4ton GM disc brakes, also trussed for 4 link and coilovers and a spare set of shafts, too.
Both axles are currently set up with flanges where I was running Toyota running gear.
Removal of the trusses and adding perches would let this bolt under any leaf sprung Toyota if that is what you want. I also have the double ended ram, joints, and AL link material I can include if you are buying the axles (will not sell until the axles are gone).
$2400 for everything, pictures will be posted later this evening. Located in Spring Hill, TN - about an hour north of Huntsville. Will meet you at the Ardmore exit off I65 if purchased at the asking price. 6l5c4O5c922l
Again, I will post pics as soon as I get home. Thanks!
