Selling the TJ. One of the most comfortable trail rigs I've ever driven. Solid suspension, reliable drivetrain, comfortable interior. The A/C and heat works, has a bikini/windjammer/tonnue combo with two-piece soft doors and factory door surrounds, new windshield. This thing drives 65mph on the interstate no problem and can tackle any trail you want. Nothing wrong with it, just time for a change.
1997 Jeep TJ
4.0 - 119,xxx miles, Brand New Optima Red Top, K&N intake with throttle body spacer, synthetic oil, modded hi-flow PS pump for assist, Borla exhaust
AX-15
Atlas 4.3 - upgraded outputs F/R, 1350 front yoke, rear CV flange for 1350 CV
ORC built driveshafts F/R with 1350s at both ends
Ford HP Dana 60 kingpin front axle - Detriot, diff ring, Rubicon Express bracket kit, Dedenbear knuckle and Solid keyed arm on passenger side. "Redneck Ram" Hydro assist steering with steering box and pump.
Ford Dana 60 rear axle - Welded spiders, Yukon Chromo shafts, disk brakes
Front suspension - Rubicon Express 8" Long-Arm with flat skid
Rear suspension - 44044 Rancho leaf spring suspension stretched WB 8" - Terra Traction rear traction bar
Rear bumper/shackle mount custom built.
15x10 steel wheels
42x15 TSLs
Custom high-clearance "tube fenders" that bolt to body and tie into grille hoop/bumper. Also bolts across engine bay under hood to protect and stiffen chassis.
Custom rocker guards, BTF Rocker Guards included (Not yet installed)
Poison Spyder Comp Corners
Warn XD9000 with perfect cable on a Warn winch mount
Interior:
Factory TJ seats but also come with new black vinyl "super seats" not yet installed
Custom 6 point cage built with DOM.
RJS four-point harness
Sony Xplode head unit with Xplode speakers in dash
CB mount on dash
A/C and Heat works
Gas tank relocated into bed and secured
Aluminum toolbox tucked under tonneu cover
Cargo rack mounted to cage in rear
The jeep will be gone through and all maintenence will be performed before purchase.
$12,800
Located in Birmingham, AL.
Gallery here:
http://www.rickybphotography.com/Rig-Features/Jeep-TJ-FOR-SALE/21788923_jxXx9v#!i=1737103857&k=vJrkKWd
1997 Jeep TJ
AX-15
15x10 steel wheels
42x15 TSLs
Interior:
CB mount on dash
A/C and Heat works
$12,800
Gallery here:
