Sold/Expired 1 ton yj project/ part out
tfreeman
Active Member
1994 jeep J tub and frame. 100% rust free. clean ***le. factory dash has been replaced with custom aluminum dash. all gauges are new. Hard top is in good shape. All lights are fully functioning. Bucket racing seats with 5 point harness. Paint is in great shape. Shackle reversal up front.
Engine is a 4 bolt main 350. No smoke. All seals and gaskets are new. New alternator, steering pump that has been drilled, and starter. mid rise intake with holly 4 barrel that was just built. New plugs and wires. oil has about 45 Min's of run time on it. Heads have recently been checked and shaved. not 100% sure how much.
Trans is a 400 Th. new pan and gasket. No slipping. Pulls great. T case is a 205 that has been twin sticked.
Front axle is a Chevy kingpin 60. 456 gears and locker. 35 spline outers.Warn lockouts. Axle was just went through. All new seals,bearings, brakes, and oil.High steer arm from eor.
Rear is a 14 bolt ff. disk brakes, 456 gears, lockrite locker. New bearings and seals also.
16 x10 steel wheels with 35x12.50 mud tires (about 50 % tread left)
All that is needed to be a driver is drive shafts and shocks.Still has factory cage.
20 gallon fuel cell mounted in the rear. red top optima that's also new.
The price like it sits is $6000. But I will also part out.
Parts Price List
-Tub and frame (includes grille) $1600
-Engine fully dressed $800
-Trans and converter $550
-T case with sticks $450
-hard top $1000
-1/2 doors $250
-full doors $800
-axles $1500 for the pair or $1300 for front and $ 500 for rear
-wheels and tires $400
-Fuel cell $100
-4" lift springs (brand new) $400
I'm having a hard time with pictures. But I can send them to whoever wants them/ would like to post them for me...
Call or text (931)-994-1860 Located in Centerville TN.
Pics I was sent
More
Last ones.
I'm interested in the 205 & cross member if your other deals fall through. I spoke with you on the phone. My name is Jesse and I am in Spring Hill. Can bring cash whenever. Thanks
