badreligion_13
- Joined
- Aug 20, 2008
- Messages
- 258
Just as the ***le says:
12 Volt SPX fenner stone power pak for rear steering. Uses hand remote to control. Can supply pictures;but, link below is to the same set-up although granger no longer offers it. However, parts and service are still available and can be purchased through SPX fenner stone (http://www.flinthydrostatics.com/SPX/SPX%20DC60SF.pdf) or through www.baileynet.com
The unit is a 4way 3 position valve, holds back tires in any position without additional valving, turns with simple push of button
Nothing wrong with valve, simply switched to a different set-up. To install all you have to do is run a ground wire, a hot wire to it, and two hydraulic lines from the valve to you hydro cylinder.
Price $350 obo plus ride if shipping. Located in cowan TN. Real picture of said unit at following link.
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=4Z339&op=search&Ntt=4Z339&N=0&sst=subset
