Front axle:
Axle housing retubed 3.5 dom , from Wide open design, also shaved.
Innovative machining solutions aluminum D60 hubs with wilwood 4 piston calipers and rotors
TMR shave kit
Rebuild/gear install kit
Yukon 5.38 shaved gears
Yukon spool
Yukon 4130 inner shafts
Solid inner C
Solid outer knuckles
Solid high steer arms
New D60 spindles
Wheel Bearing and seal kit
D60 king pin rebuilds
Lower pin caps
Ecgs slugs
5-806 ujoints
Ecgs 4130 outer stubs
Rear axle:
Axle housing retubed with 3.5 dom from wide open design. Shaved
Ruffstuff spindles tig welded on for 71”wms
TMR shave kit
Wheel bearings
Chassis unlimited diff covers shaved
Sunfire aluminum hubs with wilwood 4 piston calipers and solid wilwood rotors
5.38 shaved Yukon gears
Yukon spool
Solid pinion spacer kit
Rebuild and install kit
Just about 9k into the axles/parts.
Will sell and ship for 6400 total US sales only. Can ship freight to business address.message me or shoot me a text at 484-369-1757
TMR shave kit
Yukon spool
Solid inner C
New D60 spindles
Lower pin caps
Ecgs slugs
5-806 ujoints
Rear axle:
TMR shave kit
Wheel bearings
Yukon spool
