14 bolt spool options?
tallnate
Nashville TN
Does anybody know if they make a spool for a 14 bolt that accepts thin gears?
I have a CUCV set of tons so my 14 bolt has the detroit and the carrier spacing only accepts thin gears, 4.56 and up ratios. All I can find online is 4.10 and lower spools that require thick gears. Just wondering if there's a 14 bolt spool out there that will accept my 4.56 thin ring gear so that I don't have to buy a new 4.56 thick gear.
JRowe said:
I've got some spider gears, if you want to weld them up instead...
Yeah.. Started feeling a little vibration last weekend when I'd let off the throttle so I pulled the diff cover yesterday and found the remains of my rear pinion bearing in the bottom of the housing. So just considering what I want to do since I'll be pulling the rear end apart. I may just continue running the detroit for now. If I change my mind I'll let you know. Thanks
I have a detriot that I welded the cross bones and all together to make a spool. I was asking $50 for the whole carrier but if you already have a detriot I could mail just the cross bone and save alot on shipping. Or if you might be interested in the whole thing let me know.
Text/call 256-415-4268
Spacer is about your only choice.
We can make a 16 spline but a one off would be pricey.
