Sold/Expired .
TBItoy
Dodson Branch, TN
88 Ranger ext cab (MAY part out. I don't really have time to cut it up right now. It's wheelin season!!)
$2000 as it sits w/ stock steel wheels and street tires
Wheel and tire options:
New 40" Xterrains on 20" ProComps - $1500
New 40" Goodyear SoftTrac II Turf tires on 16x10 beadlocks - $1500
IF I do part it out:
-2.9 v6, a4od auto, dual BW tcases with DD machine doubler ($750)
-square driveshafts
-89 HPD60 front 4.10, LockRight, BTF Hi Steer, 35 spline chromoly stubs, Spicer forged ujoints, Summit Machine drive flanges ($1500)
-10.25 rear 4.10, Fully welded, RuffStuff disc brake kit ($500)
-new JVC stereo w/ ipod input, 10" Kicker CVR sub, 400w Sony amp ($200)
-front new XRC8 winch
-Full Hydro steering (ram/lines/orbital $250)
-rear traction bar
THE BAD:
-Rear t case pops out of gear. I'll include another tcase with a busted tail housing. May be able to fix it with those parts, maybe not.
-Shift shaft seal in trans leaks. I have the seal, pan gasket, and filter
-Steering pump is noisy, I have a PSC pump I'll include also.
$2000 w/ stock steel wheels and street tires
New 40" Goodyear Turf tires on 16x10 beadlocks - $1500
Re: Ranger xcab, ~ TONS~ 40"s, 2 winches, stereo $2000
i want the hydro steer set up if you part out. where are you located
I believe it is located in Cookeville, TN, but not 100% sure.
